Thread: Litronics no go
Old 02-09-2010, 02:58 PM   #3
Stroked & Blown
I guess the car realized what your username is....(bad joke)
The symptoms sound ballast related. However, there's a ballast for each headlight, so the fact that they're blinking at the same rate leads me to shared wiring.
Anyone know if the headlights share a common ground?
Do they flicker more when driving vs. parked?
Engine on vs. off?
Are they factory installed Litronics, or did you retro fit them?
Do you have the High-beam tilt harness?
Edit: Adam's comment about the switch is spot on. You can try jumping the inputs to see if it's the switch itself or the wiring going into it.
98 Arena Red 986
Stroked & Blown is online now   Reply With Quote
