Old 02-07-2010, 04:57 PM   #1
JMP
Exclamation Camber adjustment
Hi everyone, thanks for the information. I really just want to know if the rear camber can be adjusted by moving the top of the strut mounts like you can in the front. I am getting an alignment on monday and wan't to be able to tell the tech this infor if needed. I am going to run camber but at this time my left rear wheel has excessive camber and I just want it brought up to spec. If the tech can't do it by the main camber adjustment, I want him to check the strut mounts IF they can be adjusted. Thank you and I am sorry that I wasn't clear the first time, Jerry
jpeterson@petersonsoftwaresystems.com
JMP is offline   Reply With Quote
