Frunk
Lots of posts here on this problem. If you're battery is truly dead you won't be able to get into the front trunk to do a jump to the battery. You might be able to jump to the post located by the fuse box. Or, you might be able to use a battery tender hooked up through the cigarette lighter. Don't know what brands of batteries are available down under. Would suggest you not pay through the nose for a genuine Porsche brand battery. Around here an Interstate works fine.
Do a search on this forum.
