Old 02-06-2010, 03:50 PM   #2
tonycarreon
tonycarreon's Avatar
there are a lot of posts on this topic, but...
there is a jumper post in the fuse box that you can pull out, hook up a portable battery and pop the frunk.
if that doesn't work, there is a pull cable ( usually situated ) under the passenger side headlight assembly that can be accessed from the wheel well if you pull back the plastic. some owners have been known to reroute it behind the tow plug in the front bumper so check there before messing with the wheel well plastic.
