Originally Posted by root_werks
Very cool, thanks Paul.
I wound up replaced the MAF after my "cleaning" which truly was nothing more than water, and not much of that either.
It wasn't the MAF at all.
I'm still hopeful the codes aren't being caused by bad wiring or bad DME.
Since I can test the O2 I replaced, but none of the others, I did order up 3 more from GRP. They should be here by the weekend. I know, I know, shouldn't just throw parts at it. But I think it's a good set of variables to eliminate.
I'll keep the updates coming. - Dan
Bad/corroded wiring/connectors have their share of causing CELs to come on and should be inspected/tested with a good digital volt/amp/ohm meter (at least a 10 Mega ohm input impedance).
Regards,
paul...
