Originally Posted by Lil bastard
After the slight warm-up, you want the engine revving higher so that oil is flowed to the top of the engine and lubes and cools the head, cams and valves. The oil pump is not at maximum pressure or flow at idle, nor is the coolant pump.
Exactly. The FerrariChat post mentions that after a certain pressure, thicker/colder fluid (oil) doesn't flow any more, which may well be true (I'm not big into fluid dynamics, sorry), but what is that point? I'd guess it would be above idle somewhere. Combine that with the other important stuff that needs to warm up, and we arrive back at the original conclusion to not let your car sit and "warm up".
And wait a second. The world
isn't flat? Consider my mind blown.
