Old 06-14-2005, 03:59 PM   #1
bigislandboxster
Not exactly sure....
what your tire pressure should be, but I have the 17" Pirelli PZeros, 50/205 up front, and 40/255 in the rear, the recommended pressure on these are 36 psi on the rear, and 29 upfront.....This seems to work well with mine...Yours are probably a few psi higher front and rear.....
When I first purchased the car, the back tires were about 10 psi low ......and the outside of the tires are worn a bit more than the center/inside, given the camber on the rears.....So it makes sense that if your center is worn, but your outsides are OK, you may very well be overinflated.....
Lou
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
