FUEL TANK FILLER COVER
Replacing the fuel tank filler cover lock
Remove:
* the panel in the cargo compartment according to See: Interior Moulding / Trim\Trim Panel\Service and Repair
* the connector
* two screws holding the bracket in the body
* two screws holding the lock unit in the bracket.
Install:
In reverse order.
Replacing the fuel tank filler cover hinges
Press the pin out from the hinge.
Pull off the hinge.
Install:
In reverse order.
