Thread: Instant-G
Old 02-02-2010, 11:57 PM   #10
arnoldclab
Guest
Posts: n/a
Instant-G 993 Exhaust Systems for 911 3.6 Conversions (Also works GREAT for 3.2!)
Pricing:
$1345 for all through 964 engines (Rotated Flanges) , modified stock 993 cat.
$1095 for 993 engines (Stock Flanges) modified stock 993 cat
$1995/2195 when substituting 'Happy Crab" muffler, complete with all under-engine plumbing for heat.
$1445/$1695 for heat exchangers and the Happy Crab
$1195 for the happy crab alone.
Discount applies when purchaced with a 3.6 conversion kit.
On both these systems, headers modified with welded heater exit, dual outlet tips added to catalyst, and all hoses brackets, etc. are included
The happy crab includes for 100% stainless oval resonator tips
Price DOES NOT include Thom Fitzpatrick's CF heater tube shown below.
System includes:
* Factory 1-5/8" 993 Heat exchangers (modified for 964 by rotating driver's side flanges, welding and precision surfacing)
* Modified catalyst with stainless exhaust tips and provision for 02 sensor
* Heater distribution tubes -w- factory rubber elbows
* Stainless hose adapters and high temp silicone tubing (About $50 in tubing)
* All required clamps, brackets, etc.
* Complete instructions and tech support
Note: You may supply your own 993 exhaust. Modification prices are as follows:
* Rotate header flanges and surface mill $249
* Add welded adapters to accept 2.5" Silicone tubing $75
* Hi-temp silicone hoses and clamps $55
* Add straight-through exhaust tips to cats $175
Factory components available separately:
* Headers $475 per pair unmodified, $649 modified
* Catalyst $400 unmodified
* Heater distribution aluminum casting with factory rubber elbows $295
o 993-211-360-00,
o 993-211-039-02 (2)
* Catalyst bracket with clamps $65
* 993 Short Pipe (joins CF tube to sheet metal) 993-211-034-01 $25
* Short silicone hoses (45mm length) $20 pair when in stock.
