Old 02-02-2010, 10:12 PM   #2
Topless
Track rat
Topless's Avatar
The most common cause for vibration at speed is tire balance. Sometimes a wheel just throws a weight. Have your front tires rechecked. If it only happens under braking it could be dirt in the pads or warped/cheapie rotors. If steering bushings are worn out you should feel a little play and imprecision in the steering at all times.
