When it won't start...
... try disconnecting the MAF and restarting.
If it starts it's something relating to the engine compartment temperature.
Probably a bad temp sensor or a problem in the sensor's wiring.
If the ECU thinks that the engine compartment is overheated it won't allow the engine to start to protect it.
I had those symptoms in my '99 as well.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
