Old 01-28-2010, 03:58 PM   #1
JMP
Question Starting Problem?
I have a 99 Boxster. On several occasions lately, I have put the key in the ignition switch and when I attempted to start it, the key turned to the start position but nothing happened. I have made sure it is in park (Triptronic) and the gear position indicator on the dgauge confirms it is in park. A few times iot appeared to be related to the alarm system because I have turned the alrm of and on a few times and then the car started. Other times when I tried this nothing happened so I tried to put the shift lever in neutral and it has worked. It always ends up starting but if I let my wife drive the car and it does this to her, she probably couldn't figure out what to do. Any and all suggestions appreciated. Thank you!
JMP is offline   Reply With Quote
