From section 40-4 of the Bentley manual, it says "control arms to crossmember, 120 NM (88 ft-lb)." Looking at the diagram, the fastener you're referring to is a horizontal bolt that goes through the lower control arm (and presumably a rubber bushing) with a crossmember flange on each side.
