If the wheels are silver then the color is pretty standard. I believe that Wurtz supplies the paint. I, on the other hand, cleaned mu wheels up and instead of spraying them the original silver, I sprayed them Arctic Silver and clear coated them. Most any good paint supply shop can mix up a pint or so for you. I personally think that the wheels look a lot better than stock. It is an easy job as long as you work clean. Ed
