Old 01-26-2010, 04:48 AM   #1
jcb986
jcb986's Avatar
Serpentine Belt Replacement
I just replaced my belt which was the most easiest and simpliest belt replacement that I have every made. Moved both seats all the way forward, removed carpet and engine cover panels, removed the engine cover to access the belt, used a 1/2" long breaker bar with 24MM socket. You push down on the belt tensioner to release belt tension and then slide it off. Just the reverse when you install the new one. Easy as putting down the top.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
