Old 01-26-2010, 02:57 AM   #30
Dragonwind
Originally Posted by ARModen
Codes:
Fuel Filter:
I can't get to the fuel filter. While Pedro's description isn't bad, it is not a safe job to be doing without a lift. I would like to check the fuel line at the engine to see if I'm getting flow through the filter. Does anyone know the quickest way to get to the fuel rails to check fuel pressure downstream of the filter? It can't hurt too much to check that.
However if it was the fuel filter I would think the fuel pump would be on continuously attempting to get fuel to the engine. The fuel pump relay works, but it is not turning the fuel pump on.
Not true on the lift part. Get a set of ramps and you can get easy and safe access to it. This was one of the easy DIY's and won't take long.
1999 986 2.5L, Stock Exhaust (S muffler), EVO Intake, 18" Stock rims (17" during winter), IMS Upgrade, 150k+ miles and counting!
87 944S brought back to life
Dragonwind is offline   Reply With Quote
