Old 01-26-2010, 12:31 AM   #1
Lil bastard
Lil bastard's Avatar
Originally Posted by ryuujin
My 2001 Boxster has developed a 'sticky and stiff" ignition switch - the ignition key is hard to turn... I think a clean and a spray of lock lube will fix it.
Not likely, at least not for long. The starter switch (electrical portion of ignition switch) is notorious for failure and starts exactly as you describe.
Replacement switch is cheap - Audi, Mayle generic = same-same as OEM Porsche. Cost - $20USD (more if OEM).
The procedure takes about 15 min. Remove Heater tube, remove 'locking' paint from small straight screws. Pull electrical connector, unscrew starter switch. Replace switch and tighten screws, replace connector, replace heater tube - done.
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
