Drive it. Check the weather before you leave. If it looks like snow (I'm assuming you have little experience driving in snow), postpone the pickup a day or two. Even a day after a snow, the highways should be clear. Be very careful on side roads that haven't been cleared.
Remember that summer tires are very ineffective in cold weather. So even if there isn't snow on the ground, the tires will be slick; moreso if the roads are wet. Take it easy and drive it. It should be fun.
Definitely wash it thoroughly (top and bottom) to get the salt off. If there is moisture on the roads in OH, you will have salt on your car.
