Old 01-25-2010, 09:36 AM   #1
Mike_Yi
My question is, "Why would you skip a brake fluid change?" Once you have the bleeder (which costs $55), every change will cost you about $15 and take about an hour, maybe less. It's easy, doesn't take much work or getting dirty, and is a good chance to take a look at the condition of your rotors and pads.
If you every track your vehicle, you MUST change your brake fluid. I had a friend tell me that I only needed to replace the fluid that was in the calipers. His theory was that the fluid didn't circulate through the system, so only the stuff near the actual calipers got hot. I didn't think it through and we changed just a bit of the fluid before my first track day. Of course, my brakes failed as a result. We quickly changed all of the fluid at the track, and the car was fine for the rest of the day. BTW, the fluid that failed had about 45k of normal, road miles on it.
Mike_Yi is offline   Reply With Quote
