Old 01-24-2010, 01:20 PM   #16
ARModen
Originally Posted by Paul
Have you checked the alarm computer under the seat to see if it got wet?
Nope I'm back to square one now. I charged the battery and tried to start it with the fuel pump relay jumped out and it still doesn't run. The fuel pump definitely works and I don't see any water in the gas.
If it was a relay control problem the jumper would have fixed it. So now it's a bad spark issue or back to the fuel filter being clogged. Anyone know where I can check fuel pressure at the engine? Or atleast downstream of the filter? The filter is in a bad location to access with only jacks.
ARModen is offline   Reply With Quote
