Thread: Battery Issue
Old 01-20-2010, 03:45 PM   #8
rangersplash
Originally Posted by wmtee
I read your posts and have the same car, 99. I want to replace the alternator also and I looked it up in the manual and it has you going thru the top to remove a couple of nuts on studs. I thought it would be all done thru the front. What was your experience, you said it only took an hour. That sounds reasonable if you are just going thru the front panel. Thanks, Bill
Definitly through the front only. Just took out the 2 bolts once I was in there and then rotated it clockwise and it came right out. I was impressed at how easy it was. Good luck.
rangersplash is offline   Reply With Quote
