Old 01-20-2010, 01:44 PM   #2
JFP in PA
Originally Posted by Adam
I thought this would be easy, but after a half hour of using google I gave up. Is the gas tank in the boxster aluminum, plastic, or steel? Reason I ask is a friend of mine said I should fill the gas tank completely before storing the car for winter to reduce the chance of rust developing on the inside of the tank. I told him it doesn't matter because the tank is either aluminum or plastic, but I can't find info to back up my case. So can anyone confirm what the gas tank is made out of? Thanks!
Black molded plastic..................... But rather than being concerned about rust, you should be adding StaBil to the fuel to keep it from going bad and screwing up your entire fuel system....................
