It is possible to do without removing the wheel. Just turn the wheels to one side and you should be able to get under the wheel arch. It will be difficult but it is possible. If you bought the car second hand it would be worth checking the tow hole in the bumper, you might get lucky and the previous owner moved the cable there.
The next best thing would be to try a cigarette lighter battery charger, if you can get the battery to hold a small charge you should be able to pop the trunk.
