Thread: Battery Issue
Old 01-20-2010, 05:23 AM   #7
wmtee
alternator help
I read your posts and have the same car, 99. I want to replace the alternator also and I looked it up in the manual and it has you going thru the top to remove a couple of nuts on studs. I thought it would be all done thru the front. What was your experience, you said it only took an hour. That sounds reasonable if you are just going thru the front panel. Thanks, Bill
wmtee is offline   Reply With Quote
