					Originally Posted by Viper5
				 I too have a 00 986S and have had that code before.  I ended up replacing my AOS and I also found a leak in a hose.  Fixed the problem.  I probably didn't need to replace my AOS in retrospect but if you need it I could sell it to you for $50.  Your car smoking indicates that that may be the problem. |
Replaced the AOS today & cleaned the TB, started it up & let it run till warm CEL came back on & idle is rough
