Originally Posted by rangersplash
I can check this by pulling the cover behind the seats correct? How do I get this cover off?
Very easy, just remove the carpet behind the seats, which will expose a metal access panel. There are about 8-10 bolts holding the cover in place. You'll need a rachet and 10mm (I think) socket. A short extension will be useful as well. The belt will be right in front of you as you remove the cover. If your belt is broken, it's surprisingly easy and inexpensive to replace yourself.
If your belt's in good shape, the next think I'd check is the alternator. Your flickering battery and ABS lights make me think this is the problem. Ditto for the immediate shutdown after the jump. Replace your battery, which you said you were thinking about doing anyway. Search for the site for posts on troubleshooting your alternator. If you know your battery and belt are good, testing the alternator with a simple digital multimeter is easy.
My alternator recently died with absolutely no notice at ~71k miles, not more than a week after I installed a new battery. Repeated jumps got me a few miles each until I got home. I replaced the alternator with a remanufactured unit and it's been fine since.
BTW, you didn't mention your car's mileage.
