Old 01-12-2010, 04:58 PM   #1
jim_hoyland
jim_hoyland's Avatar
Front Trunk Light- What's going on ?
I got a headache; the front trunk light was out. So I thought a simple bulb replacement was needed. To be sure, I took the bulb from the rear trunk-it works-and tested it in the front trunk. No Dice
Out comes the multimeter. The front trunk light plugs into a red and yellow wire. Tested them without the light and get 12 volts; yellow wire has continuity to ground; my conclusion is there is twelve volts to the light. When I plug the light back on, NADA. Interestingly, I do not get 12 volts at the light connectors either.
The light unit works fine with a battery and works fine in the rear trunk.
Anyone been down this road ? It doesn't make sense to me.
jim_hoyland is offline   Reply With Quote
