Battery current drain
Take the car to an auto electrician and he will check current draw.
If you have access to a multimeter with a fused 10amp test facility, turn everything off remove the keys depress any alarm switches or light switches that are active when the front bonnet is open and check voltage and current draw between the + battery lead (disconnected from the battery) and the battery terminal. Have the battery tested with proper current test equipment.
Roxy
