Old 01-04-2010, 05:30 PM   #1
Frank M
Originally Posted by coreseller
I'm going to be pulling my transmission out and sending it off for a "rebuild" due to 2nd gear grinding issues. I was considering a few companies and am down to two; GBOX and Vertex out of Florida. If any of you guys have had direct experience with either of these companies could you please relate it. Feel free to IM me if you don't want to post something in the open forum. Thanks......Mark.
If you haven't been grinding the gear to long or hard its possible a gear lube change with factory lube may fix it.
the syncros are unique and factory fluid is designed to work best.
try it.
I once used aftermarket lube and after 500 miles second gear would grind
I immediately replaced the lube with factory and the problem went away.
I have also seen grinding from lube that had over 100k on it cause grinding. New lube fixed those problems too.
NH
Frank M is offline   Reply With Quote
