Old 01-03-2010, 12:10 PM   #1
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by yellowboxster01
I've got the dual canister which is their latest design. According to Fabspeed their original single canister didn't mount up at the stock points causing more drone than necessary so, they redesigned it.
All aftermarket exhausts have drone it's whether the drone is annoying or not though. Stebro's systems are annoying/headache drone that vibrates the entire interior of the car and your brain. Fabspeed doesn't have annoying resonance although it does have a slight bit of resonance. And the drone is only at about 2700 to 3000rpms. The Stebro's droned all the way from 2000-3000rpms, where you'd be in normal daily driving. 5th gear is where I hear the most resonance with the Fabspeed but, as I've said, it's not annoying and very faint.
If you don't mind me asking, why did you give up the B&B if it almost didn't drone, while giving a good sound? Did it still drone more than the Fabspeed?
