Old 01-03-2010, 12:04 AM   #2
JTP
The 2000 S wheel option was 18x7.5 front and 18x10 rears. Unless there is a significant difference in wheel mounting between the 99 and 2000 S, (besides the obvious differences of S vs non S suspension/brakes) the wider wheels should fit your car. Wider tires will give you better dry handling and better looks. On the down side, it will give you a slightly heavier steering feel, more expensive tires, and worse wet weather handling.
JTP is offline   Reply With Quote
