You may think you do not have it on recycle but you need to confirm this is actually happening.
When you switch from recycle to normal, listen for a change of air flow.
Its possible it maybe not be changing or changing very little due to a stripped pivot.
The only other thing that can cause inside frost is moisture inside the cabin.
NH
