Originally Posted by cabjose
All: would appreciate any recommendations for tire brands for my rear size 17 wheels on my 2002 Boxster S--have tried Michelin Pilots and currently have Kumhos. I would like to get more than 25K from the rear tires. I don't AX or DE my tires. Many thanks for any ideas. Cabjose.
If you want the best possible idea, then here's my suggestion:
Buy another set of 17" front wheels, and place them on the rear of the car (Yes, it will work just fine). Then install 225/45-17 tires on all 4 wheels, using a tire that has an asymmetrical tread pattern. This will allow you to rotate the tires front to rear, and side to side anytime you want.
Using the same size wheels and tires all around won't compromise the driving performance, because you don't use any of it, and you will no longer have any issues with the rear tires wearing out as fast.
Congrats, now you can drive the way that you want.
BC.
