I believe jmatta is right. The boss in the casing that must be cut down is a top dead center locator. You align to TDC and slip a retaining tool through the stock pulley to hold the crankshaft in place. It is useful when changing timing chain tensioners to keep everything aligned so don't cut it all the way off. There are other ways to fix the crankshaft at TDC but this is a quick way that techs are familiar with. On one car in our club the casing boss was completely cut off and the Porsche techs had to get creative as they could no longer use the tool.
