Originally Posted by Wingnut2u
Frank a Porsche is meant to be driven, it is a performance sports car. Please define abuse and then tell me what it looks like when they take pictures. If you do the proper maintenance and as long as you are not redlining the engine the car is not being abused nor will there be anything to document other than normal wear and tear.
wear and tear is usually not covered.
check your own particular policy
if a part broke, say a synro in the transmission (they never break unless abused), the clutch may be blued, teeth on the gear and slider would be ground down indicating continuous mashing of the grinding gear.
rear tires can show scoring from wheel spin, etc.
this is just an example there are lots more.
in short, break a part abusing the vehicle and more than likely there will be abuse evidence.
it all photographs nicely too.
