Correct - the light switch for the trunk is in the hood latch mechanism
Correct - the light is supposed to turn off automatically if left open for more than 2 hours.
What you also should know is the frunk and trunk lights both turn on when either switch is activated...
You can try some compressed air to clean out the switch and some lubricant if they are sticky. Otherwise if you need, the bulb housing easily pries out from the trunk liner so you can remove the festoon bulb...
