Old 12-18-2009, 05:28 AM   #1
hatch1517
speakers into front doors 986
I have finaly fitted speakers into my doors 97/ 986. The door loom connector has vacant holes for extra pins I passed the speaker wirring splinto two threw two of them pulled the loom out of the door and used a thin welding rod feed threw rubber boot with the help of some silicon spray wasnt to hard just takes time.I used 996 door trims not sure of the modle had to change the door handle mount plate to fit the cable, the silver handel uses a diferent cable end but you can remove the plastic bush then remove some of the material from the bottom side of the hole so the cable clip can reach threw. Or of course use your old handle.
Thanks for the feed back.
hatch1517 is offline   Reply With Quote
