Thread: Drilled rotors?
Old 12-17-2009, 04:30 PM   #9
Steve Tinker
Steve Tinker's Avatar
If you buy the Zimmermanns, make sure you get the rotors with "Z Coat". This means that the rotors are dipped at the factory to prevent corrosion. Even the part of the rotors where the pads grip are coated and the instructions specifically state "do not to remove the coating before installation" - the pads will remove it.
With the Z Coat, you will find less rust stains transferred to your wheels after rain or washing, which is a big plus.....
