Old 12-16-2009, 12:04 PM   #4
aparmex
It sounds like you have a problem at the ignition switch, these switches are made of plastic and they get damaged commonly, it is located right where you insert the key to take it out you have to go under the dashboard and it is a pain in the ### you should get your car at a electric mechanic to check it out for you, I replaced mine quite some time ago and have no problems since then...
happy boxtering !!!
aparmex is offline   Reply With Quote
