Old 12-13-2009, 06:09 AM   #1
idheaton
I think I read that yellowing of the lenses can be attributed to running aftermarket bulbs that are higher wattage than the recommended 55W and that they are actually being burned which is causing the discoloration.
You might want to check your bulbs and possibly change them to at least stop any further damage if this is the case. If they are in fact burned you are probably looking at replacement since they probably can't be buffed out even if you break them open.
- ian
idheaton is offline   Reply With Quote
