Thread: misfire 4,5,6
Old 12-04-2009, 05:26 AM   #10
DamageINC123
I believe there is a post about unplugging MAF sensor and it says if it runs better without then replace it. I believe the post is by Mike Focke. I appologize if i missed the last name. I do not have the link but its out their and is good info!! See if you can find it. You may try cleaning the MAF but i would suggest replacing it if you are sure its the issue. You may try swapping o2 sensors first since its and easy task.
DamageINC123 is offline   Reply With Quote
