The valet key does not have a light.
If you want to make sure no one played around with the key. If you do not have a remote alarm then you have a door lock key hole on the passenger side in addition to the drivers side. With the remote alarm there is only a key hole on the drivers side.
535 is the option code for the remote control alarm. You can see if this number is on your option sticker. If for some reason you do not have the option sticker then look under the drivers seat for the alarm control unit. There is a white sticker on the control unit and if you have the alarm then M535 is on the sticker.
