Originally Posted by JonnyBGood
WHen I put it into the start position, all the lights on the dash go off and I hear nothing. (I think all the lights normally go off until the car starts anyway). I may have to try jumpering the switch and see if that starts it up everytime.
Does anyone have the part number for the clutch switch?
I hope the clutch switch turns out to be the culprit, because the next idea is to check the wiring on the battery terminals, and their connection points, and then check the wiring on the starter.
If all the wiring is tight, then I would smack the starter a couple times with a hammer and rod in order to see if it frees up and starts engaging again.
If anything, tighten the battery terminals just a bit more.
BC.
