Thread: Will this work?
Old 11-23-2009, 09:36 PM   #2
Topless
Track rat
Topless's Avatar
It won't work as designed but may still do the job. Vacuum is created between the throttle body and intake manifold. If you run the AOS tube ahead of the throttle body you will get a lot less vacuum and may oil up the TB in short order. The engine will still process any blow by gasses though. I have re- routed or eliminated a lot of vacuum lines over the years but never moved one ahead of the throttle body or carb.
