play in bearings......
bearings have clearance, but generally play is bad.
you need to use a stethoscope to check for bearing noise in the waterpump...if you think you have play you will probably also have noise... any leakage ?
my wrenching experience was gained on vw's so i could be off but i'd be making plans for a waterpump replacement.
claus
03-r1100s, 11-f800st, 09-987.2, Norton Commando
auf adlers fluegeln getragen
