I tend to agree with Steve.
If it is an oxygen sensor you will more often than not experience misfires in an entire bank of cylinders and a further code for the sensor.
Check the code again, if it is the same code for cylinder 1 then pull out the coil pack and check it.
It is a good place to start at any rate.
