Old 11-11-2009, 01:17 PM   #2
Pinarelloman
The first thing I would do is check the belt tension. If that appears to be ok I would loosen the belt off and check all the pulleys for worn bearings.
Apparently if the water pump bearing gets a wobble to it it can seriously damage the engine.
I am sure someone on here with more experience will chime in for you.
Pinarelloman is offline   Reply With Quote
