Ok,
Here's the deal. If you cant catch your fingernail in the scratch, it can be wet sand and buffed. As long as the scratch is in the clear and not too deep, a professional can wet sand the scratch and use a high speed buffer and some compounds and glazes to remove it.
I would find your local body shop and see if they can do this for you. It would be worth the 30 or 40 bucks they may charge. If the scratches cannot be removed by buffing, the body shop could mix some seal gray paint for you as touch up to apply over the scratches
Best of luck!
Joe DiMonte
2001 Boxster S
Triple Black
