39K miles is good for a Boxster clutch you may find it is the 2nd clutch you are replacing. Clutch is about $600. US & another $700 if the flywheel is worn since it canot be resurfaced. Labor is about $800. Hopefully you have a written warranty which says the clutch is covered. The Boxster is one of the most difficult cars to start off in without slipping the clutch & this is what causes wear
