If you do end up having the RMS repaired you might think about having the clutch replaced as well as long at the tranny is out.
Also, since you say minor leak, you might be able to just wipe the bottom of the tranny off when needed and just keep an eye it and on your oil level until you need a new clutch and then have it fixed. Just replace the MAF yourself and save the time and money.
- ian
